| OT: WHoo caravan emissions test PASSED! https://slantsix.org/forum/viewtopic.php?t=19417 |
| Author: | Wizard [ Tue Aug 29, 2006 6:39 pm ] |
| Post subject: | OT: WHoo caravan emissions test PASSED! |
Recall I posted here with serveral questions about my plymouth Voyager's carb, etc well. Here's the latest results: ALL this took was NEW catalyst converter (was rendered dead by previous owner who fiddled with carb to get engine running on leaky manifold gasket) and muffler (old muffler guts was rotted out). Curb idle test: HC ppm 24 (limit 300) PASS CO % 0.00 (limit 1.50) PASS NOX ppm N/A RPM 1020 VALID dilution 12.2 VALID ASM2525 TEST (40KM/h) HC ppm 18 (limit 105) PASS CO % 0.00 (limit 0.75) PASS NOX ppm 519 (limit 1192) PASS RPM 2027 VALID Dilution 12.9 VALID The first E-Test result that failed was: Idle: HC 232 (limit 300) pass CO 2.16 (limit 1.5) fail NOX n/a RPM 888 valid Dilution 12.15 valid 40KM/H: HC 101 (limit 105) pass CO 1.06 (limit 0.75) fail NOX 1375 (limit 1192) fail RPM 1979 valid Dilution 12.33 valid AND I'm crying in happiness now Tulip have set of brand new license plates! Cheers, Wizard |
| Author: | SlantSixDan [ Tue Aug 29, 2006 8:54 pm ] |
Good work. Your NOx is still pretty high; I'm betting your combustion chambers are well carboned-up from running with the faulty carb. Run a can or two of BG 44K through it. |
| Author: | Wizard [ Wed Aug 30, 2006 8:00 am ] |
| Post subject: | Yes. |
Did one combustion chamber cleaned with can of acdelco's GM cleens brand before catalyst converter was replaced. Will another cleaning cycle harm the new catalyst converter? Remember, decent combustion cleaners is limited in canada, ontario. I'll try NAPA for seafoam. Is there other brands that is as good? Side note: the 2.2 head was changed before I got van with fast burn head so this bumped up the compression ratio slightly, like a point or so. Cheers, Wizard |
| Author: | SlantSixDan [ Wed Aug 30, 2006 8:09 am ] |
| Post subject: | Re: Yes. |
Quote: Did one combustion chamber cleaned with can of acdelco's GM cleens brand
No, I said BG 44K.Quote: I'll try NAPA for seafoam
No, I said BG 44K.Quote: Remember, decent combustion cleaners is limited in canada, ontario.
I live here, remember?
| Author: | Wizard [ Wed Aug 30, 2006 10:18 am ] |
| Post subject: | Dan, Ohhh! |
Oh thanks! Now I know WHERE get BG 44K, I'm surprised some dealers carries these and only one that's non-dealer is Car Medics. KIA not far from where I work, I'll walk over there and grab a bottle of BG 44K. In awhile, I'll need your lighting stuff, The 3057A bulbs jobbers carries is blowing too easily. Cheers, Wizard |
| Author: | SlantSixDan [ Wed Aug 30, 2006 1:51 pm ] |
| Post subject: | Re: Dan, Ohhh! |
Quote: In awhile, I'll need your lighting stuff, The 3057A bulbs jobbers carries is blowing too easily.
Go over to your nearest Saturn dealer and pick up a pair of front park/turn/DRL bulbs for an '04 Saturn Ion. Bulb number is 5702KA. Direct replacement for the 3057A / 3157A, but with super ultra mega long life.
| Author: | Wizard [ Wed Aug 30, 2006 4:23 pm ] |
| Post subject: | Oh, I forgot, what about the 3057 (clears for taillights)? |
Dan, That's wonderful. Question in subject line as usual. Clear 3057 bulbs Cheers, Wizard |
| Author: | SlantSixDan [ Wed Aug 30, 2006 5:00 pm ] |
Chev dealer, DRL bulb for '06 Chev Express van. Bulb P/N 4114K. Super ultra mega long life colourless clear bulb. |
| Author: | Avenger2040 [ Wed Aug 30, 2006 8:34 pm ] |
Talking about emissions, this are my emissions: Stage 5024 HC ppm: 179 CO%: 1.80 CO2: 13.2 CO+CO2: 15.1 O2%: 0.2 NOX ppm: 1181 kph: 24.6 HP Load: 13.3 Stage 2540 HC ppm: 142 CO%: 1.93 CO2: 13.2 CO+CO2%: 15.1 O2%: 0.3 NOX ppm: 1075 kph: 39 HP Load: 7.5 This lectures are below modern cars in emissions, technician was suspicious about my Duster readings, he said "they very low for a old car" what do you say people? |
