It is currently Fri May 01, 2026 4:39 am
 Post subject: Transbrake options?
PostPosted: Wed Aug 30, 2006 5:09 pm
Looking at transbrakes in summit and jegs -and before I start saving the $$$ to buy one is there any other place I should check out???
PostPosted: Wed Aug 30, 2006 6:36 pm
Yes, check with some Mopar oriented transmission builders. Griner makes a good Torqueflite valve body and should have a trans brake.
PostPosted: Thu Aug 31, 2006 5:39 am
If you don't mind one without low band apply I have a TranZact I would sell for $150. It is the type with the external can release solenoid that screws into the neutral switch hole. :shock:
I have a Griner w/low band apply in my Valiant. The only difference is that a low apply will lock at a lower staging RPM.
