Transbrake options?
https://slantsix.org/forum/viewtopic.php?t=19428
Page 1 of 1
Author:  featherduster76 [ Wed Aug 30, 2006 5:09 pm ]
Post subject:  Transbrake options?
Looking at transbrakes in summit and jegs -and before I start saving the $$$ to buy one is there any other place I should check out???
Author:  Joshie225 [ Wed Aug 30, 2006 6:36 pm ]
Yes, check with some Mopar oriented transmission builders. Griner makes a good Torqueflite valve body and should have a trans brake.
Author:  slantzilla [ Thu Aug 31, 2006 5:39 am ]
If you don't mind one without low band apply I have a TranZact I would sell for $150. It is the type with the external can release solenoid that screws into the neutral switch hole. :shock:
I have a Griner w/low band apply in my Valiant. The only difference is that a low apply will lock at a lower staging RPM.
