It is currently Wed Jun 03, 2026 6:50 am
PostPosted: Tue Aug 29, 2006 6:39 pm
Recall I posted here with serveral questions about my plymouth Voyager's carb, etc well. Here's the latest results:
ALL this took was NEW catalyst converter (was rendered dead by previous owner who fiddled with carb to get engine running on leaky manifold gasket) and muffler (old muffler guts was rotted out).
Curb idle test:
HC ppm 24 (limit 300) PASS
CO % 0.00 (limit 1.50) PASS
NOX ppm N/A
RPM 1020 VALID
dilution 12.2 VALID
ASM2525 TEST (40KM/h)
HC ppm 18 (limit 105) PASS
CO % 0.00 (limit 0.75) PASS
NOX ppm 519 (limit 1192) PASS
RPM 2027 VALID
Dilution 12.9 VALID
The first E-Test result that failed was:
Idle:
HC 232 (limit 300) pass
CO 2.16 (limit 1.5) fail
NOX n/a
RPM 888 valid
Dilution 12.15 valid
40KM/H:
HC 101 (limit 105) pass
CO 1.06 (limit 0.75) fail
NOX 1375 (limit 1192) fail
RPM 1979 valid
Dilution 12.33 valid
AND I'm crying in happiness now Tulip have set of brand new license plates!
Cheers, Wizard
PostPosted: Tue Aug 29, 2006 8:54 pm
Good work. Your NOx is still pretty high; I'm betting your combustion chambers are well carboned-up from running with the faulty carb. Run a can or two of BG 44K through it.
 Post subject: Yes.
PostPosted: Wed Aug 30, 2006 8:00 am
Did one combustion chamber cleaned with can of acdelco's GM cleens brand before catalyst converter was replaced.
Will another cleaning cycle harm the new catalyst converter?
Remember, decent combustion cleaners is limited in canada, ontario.
I'll try NAPA for seafoam. Is there other brands that is as good?
Side note: the 2.2 head was changed before I got van with fast burn head so this bumped up the compression ratio slightly, like a point or so.
Cheers, Wizard
 Post subject: Re: Yes.
PostPosted: Wed Aug 30, 2006 8:09 am
No, I said BG 44K.
No, I said BG 44K.
I live here, remember?
 Post subject: Dan, Ohhh!
PostPosted: Wed Aug 30, 2006 10:18 am
Oh thanks!
Now I know WHERE get BG 44K, I'm surprised some dealers carries these
and only one that's non-dealer is Car Medics.
KIA not far from where I work, I'll walk over there and grab a bottle of BG 44K.
In awhile, I'll need your lighting stuff, The 3057A bulbs jobbers carries is blowing too easily.
Cheers, Wizard
 Post subject: Re: Dan, Ohhh!
PostPosted: Wed Aug 30, 2006 1:51 pm
Go over to your nearest Saturn dealer and pick up a pair of front park/turn/DRL bulbs for an '04 Saturn Ion. Bulb number is 5702KA. Direct replacement for the 3057A / 3157A, but with super ultra mega long life.
PostPosted: Wed Aug 30, 2006 4:23 pm
Dan,
That's wonderful.
Question in subject line as usual. Clear 3057 bulbs
Cheers, Wizard
PostPosted: Wed Aug 30, 2006 5:00 pm
Chev dealer, DRL bulb for '06 Chev Express van. Bulb P/N 4114K. Super ultra mega long life colourless clear bulb.
PostPosted: Wed Aug 30, 2006 8:34 pm
Talking about emissions, this are my emissions:
Stage 5024
HC ppm: 179
CO%: 1.80
CO2: 13.2
CO+CO2: 15.1
O2%: 0.2
NOX ppm: 1181
kph: 24.6
HP Load: 13.3
Stage 2540
HC ppm: 142
CO%: 1.93
CO2: 13.2
CO+CO2%: 15.1
O2%: 0.3
NOX ppm: 1075
kph: 39
HP Load: 7.5
This lectures are below modern cars in emissions, technician was suspicious about my Duster readings, he said "they very low for a old car"
what do you say people?
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
