| New Timing Set https://slantsix.org/forum/viewtopic.php?t=19466 |
| Author: | Jeb [ Fri Sep 01, 2006 7:10 pm ] |
| Post subject: | New Timing Set |
I went to NAPA today and got a timing set and a timng cover gaket set. New timing set has all steel gears. Looks pretty sturdy. ![]() Dot to Dot! ![]() I will have pics of my stretched stock timing set as soon as I get it out of my car. The plastic cam gear has done started coming apart and winding up in the oil. |
| Author: | emsvitil [ Fri Sep 01, 2006 7:20 pm ] |
Do a side by side comparison of the chains so we can see the stretch.......... |
| Author: | Jeb [ Fri Sep 01, 2006 7:24 pm ] |
Betcha those teeth look like fish hooks too. And what is behind door number 1.... |
| Author: | DusterIdiot [ Fri Sep 01, 2006 8:22 pm ] |
| Post subject: | Funny...it's... |
It's a reboxed "Cloyes" setup... Make sure you watch the dot, it may be 180 degrees out (just use a longer ruler...) -D.Idiot |
| Author: | Charrlie_S [ Sat Sep 02, 2006 6:34 am ] |
| Post subject: | Re: Funny...it's... |
Quote: It's a reboxed "Cloyes" setup...
Actually they are not 180 out. When the dots are lined up the engine is at TDC compression #6, not #1. This is as it should be. With the dots lined up #1 is at TDC overlap, and you can lay a straight edge across the valves, and they should be open the same amount (split overlap).
