It is currently Tue Nov 24, 2026 8:37 pm
 Post subject: oil pump leak
PostPosted: Mon Sep 18, 2006 3:02 pm
If the leak from my oil pump can be fixed by just removing the cover and replacing the 0 ring, does this still require jacking up the engine to get access?
PostPosted: Mon Sep 18, 2006 3:10 pm
Most likely. What vehicle?
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Mon Sep 18, 2006 3:29 pm
On my 71 duster I was able to remove cover and replace o-ring without doing anything to the engine. Just be careful when you do this, the circular part of pump whose proper name escapes me at the moment is only held in by the cover and the stickynes of the oil so it may plop out.
PostPosted: Mon Sep 18, 2006 4:29 pm
Woops, I read way to fast... Yeah, the o-ring behind the cover shoudl be servicable... i was thinking about the gasket between the pump and the block. Sorry.
Used to own:
'82 Dodge D150
My other passion
PostPosted: Tue Sep 19, 2006 9:12 am
It's a '63 Valiant. It looks like you would have to pull the distributor though to get access.
Users browsing this forum: Ahrefs [Bot] and 8 guests
