| 65-66 A body gas pedal https://slantsix.org/forum/viewtopic.php?t=19637 |
| Author: | 66dartgt [ Tue Sep 12, 2006 11:01 am ] |
| Post subject: | 65-66 A body gas pedal |
I was told that a 65-66 abody with ac runs the cable style gas pedal. Is this true? If so does anyone have one they want to sell? Thank you William |
| Author: | SlantSixDan [ Tue Sep 12, 2006 11:38 am ] |
That is correct. It's a two-piece deal, consisting of a pedal bolted to the floor, which has a nylon pad at the top rear area of the pedal itself. Then, there's a pivot and S-bar assembly that bolts to the firewall. The bottom leg of the S-bar has a sort of "thumb" or "back of spoon" shape to it, which rides on the nylon pad on the pedal. The top leg of the S-bar contains the hook hole for the end of the throttle cable. This setup is used in '65-'66 A-bodies with slant-6 and factory combo heat/aircon (not the Mopar underdash type), and in '64-'66 A-bodies with V8 engines. |
