| Oil galley plug questions https://slantsix.org/forum/viewtopic.php?t=19650 |
| Author: | Jeb [ Tue Sep 12, 2006 1:50 pm ] |
| Post subject: | Oil galley plug questions |
First of, I noticed this big hole above my timing chain today. It has threads in it. Is it supposed to have a plug in it? ![]() Second, I tried to remove the galley plug behind the cam gear and it won't budge. I am afraid that I am going to break the allen wrench off in it. Are these things supposed to be be this tight? |
| Author: | 60 Pioneer [ Tue Sep 12, 2006 2:07 pm ] |
Jeb, I have the same situation. I have my block stripped down and was starting the pull the freeze plug. I have one of these threaded plugs in the front AND the back of the block. I ruined the tip of my allen wrench trying to break the front one loose. I thought about getting a hardened allen bit with a socket and see if I can't beak it free with a breaker bar. Just don't want to ruin the plug and have to drill it out. Bill |
| Author: | slantzilla [ Tue Sep 12, 2006 2:13 pm ] |
IIRC, the hole you are pointing at is a drain hole. To try and break the plugs loose, put a piece of allen wrench in them and whack it with a hammer a couple times. That may break them loose so you can turn them out. |
| Author: | Jeb [ Tue Sep 12, 2006 4:34 pm ] |
Hey Dennis I wacked it a few times with a hammer and it came right out. |
| Author: | Greg Ondayko [ Tue Sep 12, 2006 4:39 pm ] |
Jeb, As slantzilla has said, The hole you are pointing to in that posted pic is a drain hole to Drain the front lifter Galley and Lube the Timing Chain. It might have threads in it, but there should be no plug in it. Greg |
