B-Body Rotors on K-H spindles
https://slantsix.org/forum/viewtopic.php?t=19684
Author:  FrankRaso [ Thu Sep 14, 2006 6:22 am ]
Post subject:  B-Body Rotors on K-H spindles
I was reading Tom Condran's book (Performance Handling for Classic Mopars) and on Page 5 he writes:
Regrettably, '65-72 rotors can not have the stud pattern re-sized to the large 4½" pattern common to other Mopars. There is no "meat" where the machinist would drill. And outside diameters of the hubs (which center wheels) match only small bolt-pattern wheels.
The bolt pattern can be up-sized only by swapping on rotors from a '66-69 B-Body, if you can find two of those rarities in good condition. These Bendix rotors - and not the calipers from that system - match A-Body knuckles and calipers as if they were built for them. They even share wheel bearings.
I see that Layson's Restorations and the Paddock carry a unicast (combined hub & rotor) version of this rotor. Has anyone tried this B-Body rotor on their A-Body K-H disc brakes? Does anyone know which company manufactures this rotor for Layson's or who else carries this rotor?
Frank
Author:  vynn3 [ Thu Sep 14, 2006 6:40 am ]
Haven't tried them, but GOSH they're pricey! And I thought SBP KH rotors were expensive...
Of course, that could well be the good 'ol Layson's mark-up. Keep us posted if you track down the mfg and try a pair!
Author:  Joshie225 [ Thu Sep 14, 2006 7:02 am ]
Year One gets $207 each for those B-body rotors. They don't list the A-body K-H rotors.
Someone should call Stainless Steel Brakes and see if their dual bolt pattern rotors will fit the K-H disc brake spindles.
Ok, just called SSB and no dice. Of course if one wanted to put 10" drum spindles on their car they would work, but that's a screwy way to go about it.
Author:  64'4$peed [ Sat Sep 16, 2006 10:31 am ]
Is he saying that the SBP B body rotors fit 9" drum spindles? or that B body BBP rotors fit SBP Abody disc spindles?
Author:  relic-lover [ Sat Sep 16, 2006 1:16 pm ]
Post subject:  When I read it I thought
Condran was saying -
The 66-69 B body rotors (with a BBP) will fit the spindles for the Abody K&H SBP discs (65-72).
So if you have a SBP Abody K&H disc setup and you want to go to BBP wheels you could just change to those rotors.
Author:  64'4$peed [ Sat Sep 16, 2006 6:17 pm ]
got it.
Author:  SlantSixDan [ Sat Sep 16, 2006 9:55 pm ]
Frank: Be really careful with Condran's book. There are some decent suggestions in there, but it is full of factual and theoretical errors.
Author:  emsvitil [ Sat Sep 16, 2006 11:02 pm ]
If you want a book on handling modifications I'd get
How to Make Your Car Handle
by
Fred Puhn
ISBN 0-912656-46-8
Author:  FrankRaso [ Sun Sep 17, 2006 7:44 am ]
I suspected that Tom Condran (or Richard Ehrenberg for that matter) may have errors in his book, which is why I'm asking others about their experiences. I have Mopar Suspensions by Mike Martin too and I see there are errors (or at least incomplete information) in that book.
Frank
Author:  dart -66 [ Sat Feb 03, 2007 1:24 pm ]
Does anyone know, how much there is difference between ssb dual bolt pattern and original A-body K-H disc? Could it be used in with some mods?
Author:  stolan83 [ Sun Feb 18, 2007 1:33 am ]
if you are look for rotor I posted a company that still makes the small bolt rotor about 6 months a go. IF you need the info I will dig through my files and find it just let me know
Author:  dart -66 [ Sun Feb 18, 2007 2:20 am ]
I need just the info at this time.
Author:  stolan83 [ Tue Feb 20, 2007 7:49 pm ]
the brand is Centric. The part #121.63005. I payed 27.83 a peice for them. The name of my supplyer is Navada brake and auto 702-382-1020
Hope this help. The people there were really nice. they spent about an hour looking through vender books with me to these
