It is currently Tue Nov 24, 2026 1:15 pm
 Post subject: Installing crank gear
PostPosted: Fri Sep 15, 2006 5:06 am
Hey guys I am about to start wrapping up my timing chain swap out and I would like to know, what is the preferred method of installing a new crank gear? I want to make sure I have it on straight. I was thinking of using a large socket but I don't have one big enough to clear the crank key.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Sep 15, 2006 5:30 am
Contributor
I use a long V8 crank bolt and washer, and draw it down.
 Post subject: Just heat it....
PostPosted: Fri Sep 15, 2006 5:57 am
I heat the crank gear up with a propane torch or stick it on my camp stove for a bit, pull my leather gloves out and slip it over the crank snout, then let it cool down for a while.
-D.idiot
 Post subject: Ditto Dusteridiot
PostPosted: Fri Sep 15, 2006 3:36 pm
This works great especially if you're working in cramped quarters - it will slip on by hand.
Cheers!
Al T
PostPosted: Sat Sep 16, 2006 6:31 pm
I heated it on the camp stove for five minutes and it slid right on.
82 D150-225/727
Users browsing this forum: Google [Bot] and 8 guests
