It is currently Tue Nov 24, 2026 10:22 am
 Post subject: HP Fuel Pump
PostPosted: Fri Sep 15, 2006 6:50 am
Is a high-volume fuel pump overkill for a Super Six? My thinking is yes, but I was surprised to find a Holley 14 psi pump listed for the slant (or does it use a standard V8 pump?). Just wondering what everybody else is using...
vm
PostPosted: Fri Sep 15, 2006 7:18 am
The stock replacement pump is good to at least 225HP, and I have gotten into the low 14s in a 3000lb car with the stocker. I would wait until you make some serious power to upgrade.
PostPosted: Fri Sep 15, 2006 7:41 am
My car is Super 6 ......Comp 264, big valves, 9.25CR , Carter BBD .....I run out of cfm long before I run out of fuel.
A 14 lb pump without a fuel prssure reg will wreak havoc on a Super 6.
PostPosted: Fri Sep 15, 2006 7:53 am
That's a mild understatement right there. :shock:
Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
