| Installing crank gear https://slantsix.org/forum/viewtopic.php?t=19702 |
| Author: | Jeb [ Fri Sep 15, 2006 5:06 am ] |
| Post subject: | Installing crank gear |
Hey guys I am about to start wrapping up my timing chain swap out and I would like to know, what is the preferred method of installing a new crank gear? I want to make sure I have it on straight. I was thinking of using a large socket but I don't have one big enough to clear the crank key. |
| Author: | 64 Convert [ Fri Sep 15, 2006 5:30 am ] |
I use a long V8 crank bolt and washer, and draw it down. |
| Author: | DusterIdiot [ Fri Sep 15, 2006 5:57 am ] |
| Post subject: | Just heat it.... |
I heat the crank gear up with a propane torch or stick it on my camp stove for a bit, pull my leather gloves out and slip it over the crank snout, then let it cool down for a while. -D.idiot |
| Author: | Al T [ Fri Sep 15, 2006 3:36 pm ] |
| Post subject: | Ditto Dusteridiot |
This works great especially if you're working in cramped quarters - it will slip on by hand. |
| Author: | Jeb [ Sat Sep 16, 2006 6:31 pm ] |
I heated it on the camp stove for five minutes and it slid right on. |
