| HP Fuel Pump https://slantsix.org/forum/viewtopic.php?t=19703 |
| Author: | vynn3 [ Fri Sep 15, 2006 6:50 am ] |
| Post subject: | HP Fuel Pump |
Is a high-volume fuel pump overkill for a Super Six? My thinking is yes, but I was surprised to find a Holley 14 psi pump listed for the slant (or does it use a standard V8 pump?). Just wondering what everybody else is using... |
| Author: | Dart270 [ Fri Sep 15, 2006 7:18 am ] |
The stock replacement pump is good to at least 225HP, and I have gotten into the low 14s in a 3000lb car with the stocker. I would wait until you make some serious power to upgrade. Lou |
| Author: | sandy in BC [ Fri Sep 15, 2006 7:41 am ] |
My car is Super 6 ......Comp 264, big valves, 9.25CR , Carter BBD .....I run out of cfm long before I run out of fuel. A 14 lb pump without a fuel prssure reg will wreak havoc on a Super 6. |
| Author: | slantzilla [ Fri Sep 15, 2006 7:53 am ] |
Quote: A 14 lb pump without a fuel prssure reg will wreak havoc on a Super 6.
That's a mild understatement right there. |
