It is currently Wed Nov 25, 2026 7:39 am
 Post subject: Plug Gap?
PostPosted: Fri Sep 22, 2006 11:07 am
I want to start running NGK plugs in my '64 225 slant. I believe type ZFR5N. Can anybody help me out with the gap?
Thanks,
Tom
PostPosted: Fri Sep 22, 2006 11:19 am
What ignition? If stock 0.035, hei or msd and better coil, you can do 0.040 or 0.045.
The blaster 2 coil I have - in its default mounting location under alternator, if you leave the coil wire out, it will arc to the block.
PostPosted: Fri Sep 22, 2006 11:27 am
Sorry, it's a stock ignition. Still running points.
Tom
PostPosted: Fri Sep 22, 2006 11:59 am
Yep, ZFR5N, without the metal ring washer (remove it from each plug). Gap 0.035" with points.
Users browsing this forum: Google [Bot], Rick Covalt and 5 guests
