| Holley 1920 vs. smog carb... https://slantsix.org/forum/viewtopic.php?t=19787 |
| Author: | stickylifter [ Wed Sep 20, 2006 10:28 am ] |
| Post subject: | Holley 1920 vs. smog carb... |
The ol' Holley must have a bad accelerator pump because if I give it any gas while I'm in "D" it just sputters and dies. So, I still have the 1980 california smog carb fromthe previous engine that I could put on it. If I plug up all the crazy extra vaccuum ports, will that carb still work just fine? I'm not interested in a new carb or rebuilding the 1920 becuase I just need get this van moving real quick. It's become a "yard dog" and it blocks the entrance to my garage. Thanks guys. |
| Author: | fede-valiant [ Wed Sep 20, 2006 11:38 am ] |
| Post subject: | Holley 1920 |
You shoud check that pump and may be repace it, its not expensive... I have a holley 1920 and it works perfectly... |
| Author: | DusterIdiot [ Wed Sep 20, 2006 4:42 pm ] |
| Post subject: | Yipes! |
Quote: You shoud check that pump and may be repace it, its not expensive... I have a holley 1920 and it works perfectly...
The only way to replace the acc. pump in a Holley 1920 is "rebuild it", as the pump diaphragm is behind the metering block... -D.idiot |
| Author: | SlantSixDan [ Wed Sep 20, 2006 10:41 pm ] |
Boy, I surely would not voluntarily use a 1980 California-spec Holley 1945 carb if I could at all avoid it, as by rebuilding a better (earlier) carb or buying a new one. |
| Author: | argentina-slantsixer [ Thu Sep 21, 2006 12:35 am ] |
| Post subject: | Re: Yipes! |
Quote: Quote: You shoud check that pump and may be repace it, its not expensive... I have a holley 1920 and it works perfectly...
The only way to replace the acc. pump in a Holley 1920 is "rebuild it", as the pump diaphragm is behind the metering block... -D.idiot I'm sure Fede will catch on soon |
| Author: | emsvitil [ Thu Sep 21, 2006 1:13 am ] |
Quote: You should try to navigate one spanish (argentinian) dodge site, it's funny (not hilarant) messy and complicated!
What is a spark plug? |
| Author: | Eric W [ Thu Sep 21, 2006 1:49 am ] |
Its a plug that, well, sparks. Yeah, thats it. |
| Author: | argentina-slantsixer [ Thu Sep 21, 2006 5:14 am ] |
once a really enlightened member sticked out his head outta his behind in the middle of a thread and asked "what's a spark plug's gap?" teh funny amusing part is that he was asking that for real, after giving advice on other important related stuff! |
| Author: | stickylifter [ Thu Sep 21, 2006 5:46 am ] |
I took that smog carb out of the box i was storing it in and looked at it last night. ANd then I pt it right back in that box and resigned myself to rebuilding the carb. I'll look in to these "spark plugs" as you call them. I'm not sure where on the carb they go, but from the sound of it they are pretty important. Thanks guys. |
| Author: | SlantSixDan [ Thu Sep 21, 2006 9:17 am ] |
Quote: What is a spark plug?
Um, like, I have this fuel line thingy? Like, on my car? And it's, like, cracked? Like, so, it leaks? And I just, like, noticed that my car's fuel economy, like, sucks? So, like, I was, like, wondering, like, what's the effect of a fuel line leak? |
| Author: | argentina-slantsixer [ Thu Sep 21, 2006 9:35 am ] |
Quote: Quote: What is a spark plug?
Um, like, I have this fuel line thingy? Like, on my car? And it's, like, cracked? Like, so, it leaks? And I just, like, noticed that my car's fuel economy, like, sucks? So, like, I was, like, wondering, like, what's the effect of a fuel line leak? HAHAHAHAHAHAHA |
| Author: | fede-valiant [ Thu Sep 21, 2006 12:20 pm ] |
| Author: | argentina-slantsixer [ Thu Sep 21, 2006 12:56 pm ] |
Quote: Quote: Quote: You shoud check that pump and may be repace it, its not expensive... I have a holley 1920 and it works perfectly...
| Author: | fede-valiant [ Thu Sep 21, 2006 2:22 pm ] |
Quote: no como nosotros que sacamos las tuercas de la base con una pinza, nos agarramos un dedo y lo cagamos a puteadas!
Grande Juan!!! es verdad, aca hay mas cachos!!! PD: my Holley has the lateral entrance of fuel... I think its a falcon carb, because the base of the filter is blue. |
