| 73 vacuum diagram https://slantsix.org/forum/viewtopic.php?t=19812 |
| Author: | ddarnell [ Thu Sep 21, 2006 7:45 pm ] |
| Post subject: | 73 vacuum diagram |
Does anyone know where I might find a vacuum diagram for a 73 Valiant? Searched the board but the links were expired. The old Valiant has been sitting for a few years unloved. My oldest son just got a license and the Larry (the 73 Valiant) is looking real good to him. Idles like a tractor......gonna change out the carb and the normal tune -up stuff. Any help will be greatly appreciated Thanks David |
| Author: | Jeb [ Fri Sep 22, 2006 7:00 pm ] |
Do you have emmisons testing in your area? If so the only thing I would bother keeping is the EVAP canister (goes to carb bowl vent) and the vacuum advance line that goes directly to the distributor, nothing in between. If it idles bad, I would do a valve adjustment. Use Autolite 985 plugs or NGK ZFR5N plugs gapped at .035 without the washers. I am sure someone on here has a vacuum diagram. |
