| choke stat https://slantsix.org/forum/viewtopic.php?t=19815 |
| Author: | SwingLo73 [ Thu Sep 21, 2006 9:33 pm ] |
| Post subject: | choke stat |
I finally got the part for my choke but I'm having trouble seeing how it goes together... Is there a link in between the choke stat and the actual choke lever on the carb? Can somebody post a picture of the correct install and location of the choke? |
| Author: | DusterIdiot [ Fri Sep 22, 2006 6:04 am ] |
| Post subject: | Super Six... |
He needs a pic of the choke and how the rod locates on the BBD along with a pic of the "clip"... |
| Author: | 79AspenSuperSix [ Fri Sep 22, 2006 4:16 pm ] |
![]() Thats a 1969 BBD of a 318 on my factory Super6 '79 Aspen. But I took the factory choke shaft out of the orignal '79 carb and installed it in the '69 carb so its a factory hookup on the choke rod. Sorry its a little blurry I should have used the close up feature on the camera. Let me know if its not clear enough for you I can snap another if need be. |
| Author: | SwingLo73 [ Fri Sep 22, 2006 9:50 pm ] |
Does the rod on the choke stat hook up directly to the lever on the carb? Or is there another piece in between? That's what I can't see or figure out... If there is a linkage or clip I need to see that and how it hooks up... Thanks for the picture though |
| Author: | SwingLo73 [ Sat Sep 23, 2006 7:03 pm ] |
Turns out the only reason I couldn't get it was it was stuck from being over extended the wrong direction! Once I popped it loose it all made sense and went right in... so easy, boy do I feel dumb... |
