| Plug Gap? https://slantsix.org/forum/viewtopic.php?t=19824 |
| Author: | 64A100 [ Fri Sep 22, 2006 11:07 am ] |
| Post subject: | Plug Gap? |
I want to start running NGK plugs in my '64 225 slant. I believe type ZFR5N. Can anybody help me out with the gap? Thanks, Tom |
| Author: | Pierre [ Fri Sep 22, 2006 11:19 am ] |
What ignition? If stock 0.035, hei or msd and better coil, you can do 0.040 or 0.045. The blaster 2 coil I have - in its default mounting location under alternator, if you leave the coil wire out, it will arc to the block. |
| Author: | 64A100 [ Fri Sep 22, 2006 11:27 am ] |
Sorry, it's a stock ignition. Still running points. Tom |
| Author: | SlantSixDan [ Fri Sep 22, 2006 11:59 am ] |
Yep, ZFR5N, without the metal ring washer (remove it from each plug). Gap 0.035" with points. |
