It is currently Wed Nov 25, 2026 11:47 am
 Post subject: choke stat
PostPosted: Thu Sep 21, 2006 9:33 pm
I finally got the part for my choke but I'm having trouble seeing how it goes together... Is there a link in between the choke stat and the actual choke lever on the carb?
Can somebody post a picture of the correct install and location of the choke?
1973 Dart Swinger Super 6 with 71k
1976 Datsun 280ZX with Mopar I-6
 Post subject: Super Six...
PostPosted: Fri Sep 22, 2006 6:04 am
He needs a pic of the choke and how the rod locates on the BBD along with a pic of the "clip"...
PostPosted: Fri Sep 22, 2006 4:16 pm
Thats a 1969 BBD of a 318 on my factory Super6 '79 Aspen. But I took the factory choke shaft out of the orignal '79 carb and installed it in the '69 carb so its a factory hookup on the choke rod. Sorry its a little blurry I should have used the close up feature on the camera. Let me know if its not clear enough for you I can snap another if need be.
Image Image
PostPosted: Fri Sep 22, 2006 9:50 pm
Does the rod on the choke stat hook up directly to the lever on the carb? Or is there another piece in between? That's what I can't see or figure out... If there is a linkage or clip I need to see that and how it hooks up...
Thanks for the picture though
PostPosted: Sat Sep 23, 2006 7:03 pm
Turns out the only reason I couldn't get it was it was stuck from being over extended the wrong direction! Once I popped it loose it all made sense and went right in... so easy, boy do I feel dumb...
Users browsing this forum: DuckDuckGo [Bot] and 11 guests
