It is currently Tue Nov 17, 2026 9:56 am
 Post subject: Wheel Hop in reverse
PostPosted: Mon Sep 25, 2006 7:47 am
When I try to back up an incline, I get some serious wheel hop. I was told this was caused by "hot" spots on the flywheel or a warped flywheel. Is this correct? Some days I don't think I will be able to back out of a parking spot. I don't experience it going forward, it only happens in reverse. It's all about pre-planning. :)
85' D100
225cid
A833OD
PostPosted: Mon Sep 25, 2006 9:26 am
Wheel hop is a suspension issue.
PostPosted: Mon Sep 25, 2006 10:27 am
Does the clutch chatter going forward? Read through clutch troubleshooting in the FSM and it will give you a lot to think about including bad engine mounts.
PostPosted: Mon Sep 25, 2006 2:22 pm
Car Model: 63 Dart 81 D150
I get this in reverse in my 360 truck with 4 spd
look close at the tranz mount, a broken trans mount will cause this.
good luck
tophat
PostPosted: Mon Sep 25, 2006 6:32 pm
Early Mopars have the axle mounted off-center on the spring with the shorter section ahead of the axle and the longer section trailing. This design is good for resisting the tendency of the axle to twist and "wrap" the spring during a hard start, thus reducing wheel hop under hard acceleration. In reverse gear the geometry would be reversed and the longer section would be more prone to wrapping. A chattering clutch or broken rear transmission mount might exagerate the effect too.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Sep 26, 2006 7:30 am
I will check it out this weekend. I'll just keep pre-planning my parking. Thanks for the help. I'll keep you posted on what I find out.
85' D100
225cid
A833OD
