| What Kind Of Slant 6 Do I Have?? https://slantsix.org/forum/viewtopic.php?t=19889 |
| Author: | JackLe945 [ Tue Sep 26, 2006 7:42 pm ] |
| Post subject: | What Kind Of Slant 6 Do I Have?? |
Hey Guys i kno it seemes noobish to be asking this but anyone know what kind of engine ive got here?? Pictures insue:
| Author: | Joshie225 [ Tue Sep 26, 2006 8:09 pm ] |
Give us the numbers stamped on the deck of the block upder the #1 spark plug and we can tell you what flavor of slant 6 you have. |
| Author: | fede-valiant [ Wed Sep 27, 2006 1:29 pm ] |
In which car is that Slant placed? Whats your doubt? if the engine has ever been changed? I think its a 145 HP 225 Slant, (because of the colour...) |
| Author: | AndyZ [ Wed Sep 27, 2006 2:21 pm ] |
Quote: In which car is that Slant placed?
My brother had a 66 Canadian blue 170...
| Author: | JackLe945 [ Wed Sep 27, 2006 2:32 pm ] |
no i just didnt know what kind of sl6 it would be im not to knowledgeable about engines. Its presently in my 63 valiant v200 stationwagon |
| Author: | dakight [ Wed Sep 27, 2006 3:30 pm ] |
That's not the original engine for a '63 unless someone has painted it and changed the Valve Cover and PCV Valve. The numbers stamped into the pad on the block just just below the #1 spark plug, as someone already noted, will give more info. |
| Author: | fede-valiant [ Thu Sep 28, 2006 5:12 am ] |
Please, check in this links, you`ll find the answer! http://www.stockmopar.com/mopar-vin-decoding.html http://www.yearone.com/updatedsinglepag ... ndtags.asp Find the model, and you`ll get information about your car, since the year of its production, until the colour of interiors, exterior, engine y class!!! |
| Author: | SlantSixDan [ Thu Sep 28, 2006 12:20 pm ] |
Quote: That's not the original engine for a '63 unless someone has painted it and changed the Valve Cover and PCV Valve.
What're you seeing in the picture that makes you say so? The valve cover, oil cap/breather, and PCV valve are all correct 1963 types. The blue paint isn't correct for '63 (originally red), but the engine could've been repainted.Quote: The numbers stamped into the pad on the block just just below the #1 spark plug, as someone already noted, will give more info.
Yep, and also the numbers cast into the manifold side of the block, below the (three or five, which is it on this engine?) freeze plugs.
| Author: | dakight [ Thu Sep 28, 2006 4:28 pm ] |
Quote: What're you seeing in the picture that makes you say so? The valve cover, oil cap/breather, and PCV valve are all correct 1963 types. The blue paint isn't correct for '63 (originally red), but the engine could've been repainted.
I just took another look and you're correct. I first thought I saw a plastic PCV valve stuck into a rubber grommet but I see the metal cap now.
| Author: | 70valiant [ Thu Sep 28, 2006 4:34 pm ] |
I don't think that is a factory 63 battery hold down, is it? |
| Author: | Charrlie_S [ Thu Sep 28, 2006 6:28 pm ] |
Quote: I don't think that is a factory 63 battery hold down, is it?
Dealer installed option. |
| Author: | emsvitil [ Thu Sep 28, 2006 7:02 pm ] |
Show us a picture of the water pump area with the short bypass hose between it and the head and we'll tell you if it's a 170 or 225........... |
| Author: | JackLe945 [ Wed Apr 30, 2008 11:59 pm ] |
Wow everyone, thanks for all the advice and instructions, I've been stuck dealing with real life and we all know what a pain that can be haha. Anyways I got the Serial Number on the block and it is 2202857-4 so I checked out this site http://www.imperialclub.org/~imperialcl ... cation.htm and it said that it was a 225, I'm pretty sure it is anyways :shrug: if anyone can help confirm this then I would be grateful. :Edit: Oh by the way I found that number on the drivers side of the block... |
