It is currently Tue Nov 17, 2026 1:28 am
PostPosted: Thu Sep 28, 2006 4:18 pm
A833 bearing retainer adapter
I have a A833 4spd, 23 spline
I have a bearing retainer adapter ring to make the the bearing retainer larger to
fit 4.80 bellhousing
what is the best way to mount retainer adapter to transmission ?
I purchased adapter from brewers performance
thanks for any info
PostPosted: Thu Sep 28, 2006 11:22 pm
Most any "stick stuff" will hold it on the retainer's shoulder while you install the gearbox. I use 3M Super Weatherstrip Adhiesive.
PostPosted: Fri Sep 29, 2006 2:46 pm
Hello Blackduster and welcome to the forum.
Where is Oreland PA?
I am In IRWIN off the 'Pike.
PostPosted: Fri Sep 29, 2006 3:23 pm
oreland is next to fort washington Pa.
what are you near ?
PostPosted: Sat Sep 30, 2006 4:21 pm
I am not really Sure Where Fort Washington is either - I Am about 20 Miles outside Pittsburgh; SW corner of PA.
PostPosted: Sat Sep 30, 2006 4:36 pm
Im right outside philadelphia
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
