| 3spd shift likage issues Please HELP https://slantsix.org/forum/viewtopic.php?t=19906 |
| Author: | PvtDuster [ Thu Sep 28, 2006 12:29 am ] |
| Post subject: | 3spd shift likage issues Please HELP |
Ok well first I guess I should make it perfectly clear, Im new. In general just new; new to this forum new to mopars new to slant 6's and on top of all that I just got assigned to Ft. Huachuca Az. So I'm a little out of my element here, no I'm a lot out of my element here. Anyway shortly after getting here I found a 75 duster slant 6 with a 3 on the tree. Only major problem is the missing shift linkage. Mopar discontinued it (of course) cant find a junkyard with any a bodies and I don’t feel like hacking my t bar cross member so so much for after market shifters. So my question is, where can I find a shift linkage for my beater? Thanks for any help you can give, Pvt Davidson |
| Author: | dakight [ Thu Sep 28, 2006 4:42 am ] |
You should post this in the "Parts Wanted" forum. In the meantime try looking on http://car-part.com/ They probably don't list the linkage seperately but you can do a search for the transmission then contact the yard and see if they have the linkage. There are a few Mopar yards around but the one that seems to come up most often in my searches is one in Thatcher, AZ which is probably about a 4 hour drive for you. There's also a couple around the Phoenix area and also I believe 1 or 2 around Tucson. Good luck. I have the linkage for a '62 but it's unlikely that it would work for you. |
