| AC with the Offy 2 singles manifold https://slantsix.org/forum/viewtopic.php?t=20000 |
| Author: | 65 dartman [ Tue Oct 03, 2006 5:58 pm ] |
| Post subject: | AC with the Offy 2 singles manifold |
Would I be correct to say that the factory V AC compressor will not fit a motor equipped with the Offy 2 single carb manifold? Might a rotary compressor as found on late F Bodies and M Bodies work instead? |
| Author: | Bren67Cuda904 [ Tue Oct 03, 2006 8:42 pm ] |
I would say most likely not. Here are some pics that might help you. ![]() [/img] |
| Author: | 65 dartman [ Wed Oct 04, 2006 5:47 am ] |
Thanks for the pictures! I'd say even with the rotary compressor, AC not possible with the twin singles. Thanks again! |
| Author: | slantvaliant [ Wed Oct 04, 2006 11:04 am ] |
Looks too tight with the factory brackets and compressor location. Maybe you could fabricate brackets that place the compressor lower, further to the driver's side? |
| Author: | 65 dartman [ Wed Oct 04, 2006 4:40 pm ] |
Might be able to cobble up some brackets and fit a rotary compressor where the power steering pump would go if the car had PS |
| Author: | SlantSixDan [ Thu Oct 05, 2006 6:07 pm ] |
Be advised there are at least two different bracketry setups for the V-type compressor on the slant-6. The early-type brackets (I want to say up to '66, maybe a couple years later) mount the compressor closer to the engine block; the later brackets move it several inches farther over towards the driver's side. When I used late-type brackets in my '65, it put the left outboard compressor head bolt into the battery case. I could've solved this with a smaller/different battery, but never got around to it. It also does seem to me that one or another type of round-body compressor could be mounted on a "block hugger" type bracket down under the manifolds, where the DC generator was mounted on '60-'62 cars so equipped. |
| Author: | argentina-slantsixer [ Fri Oct 06, 2006 9:38 pm ] |
newer, smaller compressors from modern cars? old style AC won't fit in mostnarrowa's engine bay (up to'67 I think) |
| Author: | SlantSixDan [ Sat Oct 07, 2006 8:00 am ] |
Quote: old style AC won't fit in mostnarrowa's engine bay (up to'67 I think)
The old-style (V2) compressor was used in A-bodies with dealer or factory A/C starting in '62, actually...!
| Author: | argentina-slantsixer [ Sat Oct 07, 2006 8:58 pm ] |
Quote: Quote: old style AC won't fit in mostnarrowa's engine bay (up to'67 I think)
The old-style (V2) compressor was used in A-bodies with dealer or factory A/C starting in '62, actually...! |
