Intercooler hose routing?
https://slantsix.org/forum/viewtopic.php?t=20096
Author:  Matt Cramer [ Sun Oct 08, 2006 6:43 pm ]
Post subject:  Intercooler hose routing?
For those of you who have intercoolers in A-bodies, how did you route the hoses?
Right now it looks like the easiest way to add an intercooler to my '66 Dart and find space for all the plumbing is going to be moving the battery to the trunk (with all the associated complications of having to follow both SCCA and NHRA rules about this due to how many places I plan to run this car). Any thoughts on a good way of routing the hoses without doing this? Or am I better off just moving the battery out of the way?
Author:  Rob64GT [ Sun Oct 08, 2006 10:31 pm ]
My 66 Valiant has very little room for an intercooler up front, I am thinking about using an air to water intercooler. Better for the 1/4 mile but maybe not as efficient on the street as an air to air. I do like th idea of icewater for the intercooler for the 1/4 mile
Author:  Sam Powell [ Mon Oct 09, 2006 12:03 pm ]
I put my battery in the trunk. Accel recommends running your hot and ground wire for the ECM harness all the way back to the trunk. My intercooler goes in and out on the battery side. It would be smoother if it could be just through; in on one side, and out on the other, but my surge tank is in the way right now. It is surprising how full this engine compartment has gotten. I remember when you could stand inside the compartment with your feet on the ground, to work on it for some operations
I just began to wonder if there are any leaks in my intercooler system. I have been cogitating on a system to put it under pressure and check it. Maybe use a shraeder valve, and block both ends of all the piping with plugs of some kind.
Sam
Author:  Matt Cramer [ Tue Oct 10, 2006 6:03 pm ]
Thanks, Sam. I've got one advantage with the layout I'm using: The surge tank and all fuel pumps are mounted under the car, just ahead of the rear axle (making sure the axle wouldn't hit them took a bit of work!).
Maybe I will have to go with the trunk mounted battery after all.
Author:  cmexlr8 [ Thu Oct 12, 2006 9:25 am ]
Sam
Some shops have a thing called a "bong" that can detect leaks. I know one of the dealerships here has one. I think it uses smoke or something to find leaks. Maybe somewhere near where you live will let you 'hit their bong' :wink:
Author:  DionR [ Thu Oct 12, 2006 10:09 am ]
I know of a couple of people that have made it work on street car. I think the trick is to mount a thin radiator up front to cycle the intercooler coolant through. Don't think it takes much.
The best setup I know of is a Dakota running an air-to-water intercooler with the chiller for the water in the bed. He set it up so that his A/C runs through a chiller in the bed so that while he is running around town with the A/C on, he is cooling his IC water at the same time. He said it worked really well. I will try and find a link.
Author:  DionR [ Thu Oct 12, 2006 10:26 am ]
Ok, it wasn't quite like I remembered it, he runs the coolant through the heater core with the A/C on and then through a 2.5 gallon tank in the bed. He has a neat setup for raceday as well.
Not sure what he does for heat, but he lives in Arizona (I think), so maybe the least of his concerns is cold weather. :D
Here is the link, read the whole post by Duner. Looks like the pertinent info is about 4 or 5 paragraphs in.
http://www.turbomustangs.com/smf/index. ... #msg239039
Author:  mcnoople [ Thu Oct 12, 2006 5:54 pm ]
An idea I always liked for the early a bodies was to lower the battery down on top of the frame rail and move it outboard so it sits centered over the rail. If you use a small enough battery (like a 51R) it will clear any plumbing you can possible think up. This is one of the plans for my project valiant It looks like the top of the new battery would end up about where the bottom of the tray was before. Of course it req some inner fender mods but it would keep it where it belongs next to the engine.
Author:  Sam Powell [ Fri Oct 13, 2006 7:26 pm ]
If you look under the hood of the 80's 5 series BMW's, they put the battery down low on the frame, just where you suggested. . It is a slant six as well.
