| Ballooning radiator hose!! https://slantsix.org/forum/viewtopic.php?t=20098 |
| Author: | Tripower222 [ Sun Oct 08, 2006 8:00 pm ] |
| Post subject: | Ballooning radiator hose!! |
I just drove my dart for about an hour and when I parked it I checked under the hood and saw that the upper radiator hose was stretched tighter than a...well, really tight. My temp gauge doesn't work so I don't know how hot it was running but I don't understand why this would happen, since I have a 16 lb. cap and an overflow tank that had only a little bit of coolant in it. It seems that the pressure was clearly not overcoming the cap and filling the tank. I guess this means the car is overheating, huh? Question is, why. Are these stock radiators known to perform poorly? |
| Author: | SlantSixDan [ Sun Oct 08, 2006 8:02 pm ] |
Just means your radiator hose is old/weak or defective. In either case, replacing it with a good quality hose will fix the problem. The stock radiators work well if they are in good condition. |
| Author: | jpope [ Sun Oct 08, 2006 8:38 pm ] |
And it probably wouldn't hurt to get a new cap. Or at least have yours checked out to make sure it's holding the correct pressure. |
