It is currently Mon Nov 16, 2026 9:14 am
PostPosted: Sat Oct 14, 2006 3:04 pm
I'm wondering if someyears of
904' s are better than others to use for a street/bracket racer project. Thanks
PostPosted: Sat Oct 14, 2006 7:47 pm
The large input shaft / big hub version is the way to go, 1968 and up.
You need to decide if you want a low first gear (wide ratio) which started in 1981. Avoid the lock-up torque converter units if you are going for high performance.
Wide bands, more clutch discs and 4 pinion planetary gears are in the V8 version of the 904 and these parts can be swapped into a SL6 904 to make a super HD unit.
Users browsing this forum: Amazon [Bot] and 7 guests
