| different setups for kickown linkage? https://slantsix.org/forum/viewtopic.php?t=20164 |
| Author: | young6 [ Thu Oct 12, 2006 6:56 am ] |
| Post subject: | different setups for kickown linkage? |
I'm about to start the conversion from /6 to super6 on my '75 Valiant. I've already picked up all the parts I need with the exception of the carburetor. I'm not sure which carb to pick or how the kickdown linkage will differ between the choices. Currently, I have the kickdown off of a '77 Volare supersix setup. I'm wondering which carbs the volare linkage will fit besides the 2280/6280? I'd like to go with a holley 2300. How will the kickdown linkage vary between the stock carbs and the 2300? Will I need to fabricate my own? -chris |
| Author: | CStryker [ Thu Oct 12, 2006 10:39 am ] |
If you look through recent posts, this topic has been discussed /several/ times. The stock linkage is designed to work with the BBD. Anything other than that will require modification. The Lokar cable is a relatively painless and much more versatile swap, however, and possibly cheaper than trying to track down an original setup. |
