truck talk
https://slantsix.org/forum/viewtopic.php?t=20174
Page 1 of 1
Author:  bcajm5 [ Thu Oct 12, 2006 2:24 pm ]
Post subject:  truck talk
anybody got a dump truck? i got a 1991 dodge 1 ton dump. it is a 4 spd w/ a pto bolted to side of the trans. cannot seem to find out what type of trans this may be? doesnt really look like a 435. pto is bolted on the side w/ 6 bolts which drives the hyd pump. one guy told me ford used this setup. truck is a factory 360 w/ tb, no 4wd. what do u guys think? i pulled the drain plug and a lot of hyd oil came out, thinking maybe the seals may be bad that sep gear oil and hyd oil???
Author:  66aCUDA [ Thu Oct 12, 2006 2:51 pm ]
I have a D350 w/ 360 4speed 4 door long bed 1985. do you think the xmission might be the same? I could crawl under and see if I can find the data plate if you like.
Frank
