| carb kick down linkage? pic https://slantsix.org/forum/viewtopic.php?t=20176 |
| Author: | 56 Dodge [ Thu Oct 12, 2006 2:33 pm ] |
| Post subject: | carb kick down linkage? pic |
Has anyone else had this problem My carb that is not original throttle linkage runs right to left I am trying to fabricate kick down linkage. The white piece from the throttle linkage to the kick down linkage is my attempt. The carb is a Weber Carter Motorcraft and the tranny is a 904. Do I need to locate an original carb for the linkage to work? I have a Lokar cable, but with the way the throttle linkage works it will not work.Thanks for all the help and Patience in teaching me how to post pictures!
| Author: | 56 Dodge [ Thu Oct 12, 2006 7:17 pm ] |
I am not sure what the carb is off thanks for the pic of the linkage I mine is not working instead of kicking down all I know is mine is not working it keeps slipping back into neutral. |
