It is currently Mon Jun 15, 2026 1:30 am
 Post subject: Cleaning an Alt.?
PostPosted: Fri Oct 13, 2006 8:47 am
I'd like to clean my slavage yard Alt. to make it look like a new one. How or what chemical should I use to bring the casing back to a like new look. I'd like not to disesemble the alterator. I am worried about killing it with strong chemicals. Disesemble maybe the best way to do it, I just have never opened one before. Mine is not real dirty, its just not new looking.
http://www.renaissanceracing.com/images ... ntSerp.JPG
PostPosted: Fri Oct 13, 2006 9:15 am
Use etching-type mag wheel cleaner from the parts store, then spray it with some kind of clear-coat (paint).
PostPosted: Fri Oct 13, 2006 10:17 am
The ecthing won't hurt the windings?
PostPosted: Fri Oct 13, 2006 10:53 am
No, because:
1) the windings are coated with a very durable elastomeric coating, and
2) You don't need to leave the cleaner on the case long enough to cause problems.
PostPosted: Fri Oct 13, 2006 5:42 pm
You can start by degreasing it with electrical cleaner (the stuff you clean the inside of computers and circuit boards with)...
