It is currently Sun Nov 29, 2026 2:37 am
 Post subject: oil sender
PostPosted: Wed Oct 18, 2006 2:35 pm
does anyone know the pipe size for my oil sender. Going to mech. gauge.
PostPosted: Wed Oct 18, 2006 2:49 pm
3/8" NPT if I recall correctly. Can anyone confirm or refute?
The "Silver Bullet"
87 Ram D150
PostPosted: Wed Oct 18, 2006 2:51 pm
The location under the oil filter (on the oil pump) is 3/8 pipe.
The location on the bolck is 1/8 pipe.
PostPosted: Wed Oct 18, 2006 3:23 pm
which one should be used? either one?
PostPosted: Wed Oct 18, 2006 4:37 pm
Your '67 will only have the port on the oil pump. The boss on the block was only drilled and tapped on earlier engines.
PostPosted: Wed Oct 18, 2006 6:18 pm
Car Model: 63 Dart 81 D150
eariler? how eariler?
tophat
Users browsing this forum: DuckDuckGo [Bot] and 5 guests
