| 904, Someyears are better than others? https://slantsix.org/forum/viewtopic.php?t=20229 |
| Author: | flatiron [ Sat Oct 14, 2006 3:04 pm ] |
| Post subject: | 904, Someyears are better than others? |
I'm wondering if someyears of 904' s are better than others to use for a street/bracket racer project. Thanks |
| Author: | Doctor Dodge [ Sat Oct 14, 2006 7:47 pm ] |
The large input shaft / big hub version is the way to go, 1968 and up. You need to decide if you want a low first gear (wide ratio) which started in 1981. Avoid the lock-up torque converter units if you are going for high performance. Wide bands, more clutch discs and 4 pinion planetary gears are in the V8 version of the 904 and these parts can be swapped into a SL6 904 to make a super HD unit. DD |
