It is currently Sat Jun 20, 2026 3:43 pm
 Post subject: Clean relay/fuse box
PostPosted: Mon Oct 16, 2006 2:54 pm
I am looking for a compact fuse and relay holder. I'd like to be able to mount the box in the engine bay to hold the relays for the headlights, A/C clutch, Alt field drop on WOT relay, and nitrous arming. So where looking at something like 5-7 relays and a few ATC type fuses. Oh and maybe 1 or 2 maxi fuses.
I don't want a plastic box that all this piles into. I want them to plugin.
Any ideas?
PostPosted: Mon Oct 16, 2006 5:30 pm
I suppose it might be possible to adapt the engine bay fuse and relay block from a late 90s Dakota.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Oct 16, 2006 8:19 pm
Check with Painless Wiring.
You might find something in a hot rod parts catalog.
Jerry
