| oil sender https://slantsix.org/forum/viewtopic.php?t=20322 |
| Author: | Bren67Cuda904 [ Wed Oct 18, 2006 2:35 pm ] |
| Post subject: | oil sender |
does anyone know the pipe size for my oil sender. Going to mech. gauge. |
| Author: | Super6 [ Wed Oct 18, 2006 2:49 pm ] |
3/8" NPT if I recall correctly. Can anyone confirm or refute? |
| Author: | Doc [ Wed Oct 18, 2006 2:51 pm ] |
The location under the oil filter (on the oil pump) is 3/8 pipe. The location on the bolck is 1/8 pipe. DD |
| Author: | Bren67Cuda904 [ Wed Oct 18, 2006 3:23 pm ] |
which one should be used? either one? |
| Author: | Joshie225 [ Wed Oct 18, 2006 4:37 pm ] |
Your '67 will only have the port on the oil pump. The boss on the block was only drilled and tapped on earlier engines. |
| Author: | tophat [ Wed Oct 18, 2006 6:18 pm ] |
Quote: Your '67 will only have the port on the oil pump. The boss on the block was only drilled and tapped on earlier engines.
eariler? how eariler? tophat |
