Weiand WD4 Intake?
https://slantsix.org/forum/viewtopic.php?t=20350
Author:  rosspulliam [ Thu Oct 19, 2006 8:56 am ]
Post subject:  Weiand WD4 Intake?
Does anyone have any knowledge of this intake? I know it looks just about identical to the Offy intake, but does anyone have any firsthand knowledge of it being good or bad?
Link to Ebay
Author:  Reed [ Thu Oct 19, 2006 9:06 am ]
I think I would avoid it. The inboard throttle bores are way to close to the motor. The fuel distribution would be very poor with most of the fuel going to cylinders 2-5. 1 and 6 would hardly get any mixture flow.
here is a pic of the offy intake. You can see how all four throtle bore holes are much more "outboard" than the Weiand. This allows for a more even fuel distribution.
Here is that Weiand for comparison:
Author:  Dart270 [ Thu Oct 19, 2006 2:22 pm ]
I don't think there will be a huge difference between the two, altough I've never used a Weiand. IIRC, Meril Bruner used the W on his "Half Hemi" car when he went in the 12s for the 1st time in the 1980s.
Author:  Matadem [ Thu Oct 19, 2006 4:24 pm ]
I have the weiand bought it from some1 on .com site
Author:  zedpapa [ Thu Oct 19, 2006 6:03 pm ]
i don't see much of a difference in the two. i have a clifford manifold and mounted the carb with the primaries furthest from the engine to help with fuel distribution. the only problem i see with right now is that under hard acceleration, the front jet may go dry. i am consider getting the foam inserts from summit to put in there to help with that. but with the clutch slipping as much as it does, i don't have to worry about that right now.
zedpapa
