| difference between 170 and 225 https://slantsix.org/forum/viewtopic.php?t=20383 |
| Author: | highleroy [ Fri Oct 20, 2006 10:58 am ] |
| Post subject: | difference between 170 and 225 |
Recently I purchased a slant motor assuming that it was a 225, but to make sure I wanted to measure it, but the only measurement I can find is that the 170 is 1" shorter than the 225... But what does a 170 measure? |
| Author: | 70valiant [ Fri Oct 20, 2006 2:17 pm ] |
Look at the hose going from the water pump to the head, on a 170 it is about 2" long on a 225 it is about 3" long. It would be more accurate to just clean the pad on the spark plug side of the block above spark plug #1 and read the numbers. A 225 is a "stroked" 170. The bores are the same but the 225 has a 1 inch longer piston stroke. |
| Author: | slantvaliant [ Fri Oct 20, 2006 2:38 pm ] |
The hose: ![]() The pad: ![]() Note: These are both on a 225. |
| Author: | r66cuda [ Fri Oct 20, 2006 11:54 pm ] |
| Post subject: | Thanx, slantvaliant! |
Hey, slantvaliant, just wanted to say thanx for also answering my question before I even asked! Really appreciate the photos! My 1st day here. I have a '66 'Cuda with a non-stock /6. It had a /6 stock, according to steel stamp on inside driver fender, but this one has EGR, which is 70's. I can't wait to go outside tomorrow to see tag under plug #1, and bipass hose. Also, I may need to replace tranny, but not sure what year. I see a stamp on center driver's side of block in large letters 0174. Does that mean Jan., 1974? Love your quote: "Those @#$% engineers!" Rich |
| Author: | 70valiant [ Sat Oct 21, 2006 6:27 pm ] |
Well done slantvaliant |
