8 1/4 A Body Rear
https://slantsix.org/forum/viewtopic.php?t=20390
Page 1 of 1
Author:  66aCUDA [ Fri Oct 20, 2006 3:48 pm ]
Post subject:  8 1/4 A Body Rear
I would like to put an 8 1/4 surgrip rear on my 66 drag Cuda. What would be a good donor car? I not looking to do a Major rebuild on the axles etc. The motor and tranny a targeted to be a 12sec car. Also if anyone has any gear ratio reccomendations.
thanks
Frank
Author:  Jeb [ Fri Oct 20, 2006 7:05 pm ]
A Volare or Aspen might have what you are looking for, although beware of those that have gears higher than 2.76. They have a different housing and can not be geared lower. I would check mid 70's mainly, that is before the gear ratios got ridiculoulsy tall.
If you plan on narrowing your rear, then most 1980s Dodge pickups have an 8 1/4 or 9 1/4. 250's and 350's were 8 lug models though, stay away from those.
Or you could get a 9 inch Ford. You'll never break it.
Author:  Charrlie_S [ Sat Oct 21, 2006 1:28 am ]
For a 12 sec car, depending on tire size, you will want a ratio of about 4.30-4.56-4.88
Author:  DusterIdiot [ Sat Oct 21, 2006 6:05 am ]
Post subject:  The bolt in...
If you get lucky to find one:
Any 1973-1976 Duster,Dart, Valiant, Dart Sport with a 10 bolt round rear cover will be a good core...if the car is OEM and has disc brakes and a 3 speed manual on the floor then it will most likely have the 8 1/4" if it's still all original.
Author:  dakight [ Sat Oct 21, 2006 6:20 am ]
There are several listed in car-part.com. Look for a 74 Dart with a 10-bolt rear axle.
Author:  66aCUDA [ Sun Oct 22, 2006 6:13 am ]
Thanks for all the info Guys. My Cudas are on the way here and its time to get started finding parts.
Frank :D
Author:  Doctor Dodge [ Mon Oct 23, 2006 9:46 pm ]
Set the car up with a Mopar 8 3/4 and you will be glad you did.
Author:  66aCUDA [ Tue Oct 24, 2006 6:53 am ]
Thanks Doc If I can find /afford one.
Frank
Author:  Bren67Cuda904 [ Thu Oct 26, 2006 5:51 pm ]
? when replacing a 7 1/4 with a 8 1/4 from an A-body the driveshaft will need to be shorten. Does anyone know how much for my Barracuda? Also is the u-joint the same for the 8 1/4?
