Slant Six Forum https://slantsix.org/forum/ |
Just got head gasket AP210 https://slantsix.org/forum/viewtopic.php?t=20489 |
Author: | Bren67Cuda904 [ Wed Oct 25, 2006 3:10 pm ] |
Post subject: | Just got head gasket AP210 |
Just received my head gasket (Permaseal Ap210 (3.66 bore)) and noticed that it said 225 slant 6 62-70. I've got a 74 block and using revised camber spark tube type head (68-75 style). Should I have any problems here? Why wouldn't it say from 62-75? or later? |
Author: | argentina-slantsixer [ Wed Oct 25, 2006 3:40 pm ] |
Post subject: | |
are you going to bore your block 3.66? please, I'd love to hear how you're going to get away with that .260 extra. I don't think there's enough material between cylynders, but maybe you have a great mechine shop that cae up with some epiphany... for the model label I wouldn't be concerned, those parts guys wouldn't be able to tell the difference between a 5/16 bolt and a 7/16 if they were mislabeled, |
Author: | Joshie225 [ Wed Oct 25, 2006 4:40 pm ] |
Post subject: | Re: Just got head gasket AP210 |
Quote: Just received my head gasket (Permaseal Ap210 (3.66 bore)) and noticed that it said 225 slant 6 62-70. I've got a 74 block and using revised camber spark tube type head (68-75 style). Should I have any problems here? Why wouldn't it say from 62-75? or later?
Didn't that gasket come from down under? Where the slant got replaced by the domestically built 'hemi' six around 1970-71? The head gaskets for everything but the aluminum engines are interchangeable.Also, (combustion) chamber is spelled with an h. Camber is the outward or inward tilt of a wheel. |
Author: | Dart270 [ Wed Oct 25, 2006 6:05 pm ] |
Post subject: | |
You'll be fine with that Aussie gasket. Very nice piece. The big bore is helpful for putting in bore notches for flow, not necessarily for bigger overbores. Lou |
Author: | Pierre [ Wed Oct 25, 2006 6:05 pm ] |
Post subject: | |
Yup, I resold one of the gaskets I got from the group buy as plans changed. Glad to hear it arrived safely. |
Author: | Bren67Cuda904 [ Wed Oct 25, 2006 7:54 pm ] |
Post subject: | |
we're not going to bore to 3.66, thats just what the gasket can handle. 10-4 on the chamber and not camber. Missed the H. The packaging was over the top. The only thing one could do more would to have used a piece of hardwood instead of pine as the backbone in the packaging. When it came I smiled and said "dam dude you wheren't *@#%ing around" |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
