It is currently Sat Nov 14, 2026 2:59 pm
 Post subject: U-bolts/plates
PostPosted: Wed Nov 01, 2006 12:51 pm
I am changing from a 7 1/4 to 8 1/4. I know I'll need a larger U-bolt diameter, but will I need to use differant shock plates?
PostPosted: Wed Nov 01, 2006 12:58 pm
yes
PostPosted: Wed Nov 01, 2006 6:00 pm
Can I just redrill mine or slot them a bit?
PostPosted: Wed Nov 01, 2006 6:03 pm
If I get new plates will any 8 1/4 equipted car be a donor?
PostPosted: Wed Nov 01, 2006 6:19 pm
Any car with the 3 inch axle tubes, except, the ones with the iso mount (rubber bushings, on the spring mount).
PostPosted: Wed Nov 01, 2006 7:09 pm
You can get brand new plates from Mancini Racing (www.manciniracing.com) for $90 for both sides together. All of the places I'm listing also have the U-bolts.
Also you can try Springs and Things: www.espo.com
And failing that there's always Just Suspension: www.justsuspension.com
'68 Dodge Dart 4dr Sedan
