U-bolts/plates
https://slantsix.org/forum/viewtopic.php?t=20584
Page 1 of 1
Author:  Bren67Cuda904 [ Wed Nov 01, 2006 12:51 pm ]
Post subject:  U-bolts/plates
I am changing from a 7 1/4 to 8 1/4. I know I'll need a larger U-bolt diameter, but will I need to use differant shock plates?
Author:  Charrlie_S [ Wed Nov 01, 2006 12:58 pm ]
yes
Author:  Bren67Cuda904 [ Wed Nov 01, 2006 6:00 pm ]
Can I just redrill mine or slot them a bit?
Author:  Bren67Cuda904 [ Wed Nov 01, 2006 6:03 pm ]
If I get new plates will any 8 1/4 equipted car be a donor?
Author:  Charrlie_S [ Wed Nov 01, 2006 6:19 pm ]
Any car with the 3 inch axle tubes, except, the ones with the iso mount (rubber bushings, on the spring mount).
Author:  Patrick Devlin [ Wed Nov 01, 2006 7:09 pm ]
You can get brand new plates from Mancini Racing (www.manciniracing.com) for $90 for both sides together. All of the places I'm listing also have the U-bolts.
Also you can try Springs and Things: www.espo.com
And failing that there's always Just Suspension: www.justsuspension.com
