| Clutch Fork Return Spring https://slantsix.org/forum/viewtopic.php?t=20643 |
| Author: | bwhitejr [ Mon Nov 06, 2006 5:23 pm ] |
| Post subject: | Clutch Fork Return Spring |
Where can I get a clutch fork return spring for a 1980 D-150 truck with a A-833 OD transmission and a Slant Six? Everyone I find is too short. I need one about 3 1/2" not the 2 1/2" one I am being offered. I see some on some websites that are for big blocks. Someone help, please!! bwhitejr |
| Author: | rock [ Wed Nov 15, 2006 8:27 am ] |
| Post subject: | I got one at a local parts place and |
Hey BWHite, I too needed one for my truck when I did the 833 swap. I was and am using a wilwood pull cylinder to the fork but don't see why that would make any difference. THE spring I got works fine and is made with one hook end and a 5 inch long straight end that you insert to what tension you want and bend into a final hook. IN other words one stock hook, one hook you can make. Got it a local parts place. I can look up the number and all but I betcha most places may have the same thing. I think it was about $5.50. rock '64d100 |
