| 904 weight? https://slantsix.org/forum/viewtopic.php?t=20675 |
| Author: | VE Safari [ Thu Nov 09, 2006 5:59 am ] |
| Post subject: | 904 weight? |
How much does a slant 904 Torqueflite weigh, roughly? Is it an easy one-man lift and carry? |
| Author: | Charrlie_S [ Thu Nov 09, 2006 7:03 am ] |
I am the original 98 lb weakling, and I can lift and carry it. Not easily, but I can pick it off the floor and put it on the bench, or lift it out of a truck, and put it in the shop. |
| Author: | Joshie225 [ Thu Nov 09, 2006 9:12 am ] |
They are pretty light, but I still use a jack when I put one in or take one out of the car. If you're moving one around taking the torque converter out helps. |
| Author: | Rust collector [ Thu Nov 09, 2006 10:34 am ] |
If you are dropping it out of a car, it really helps to have a jack, or a big gut. They are pretty light, and won´t break more than a rib or two. |
| Author: | Dart270 [ Thu Nov 09, 2006 12:44 pm ] |
Trans and torque converter are around 125lbs (55-60kg). I generally use a jack and lift it down off the jack when it's near the ground. Lou |
| Author: | VE Safari [ Thu Nov 09, 2006 1:43 pm ] |
Quote: Trans and torque converter are around 125lbs (55-60kg). I generally use a jack and lift it down off the jack when it's near the ground.
Thanks for the responses. I just bought one off eBay, and have to pick it up from the elderly lady seller. I'm guessing she probably won't be able to help me load up the car by the sound of her.
Lou |
| Author: | Ron Parker [ Thu Nov 09, 2006 4:21 pm ] |
Make sure she doint have a brand new shiny red Super Stock Dodge around if so let me know mate. Thanks Ron Parker It Aint Over Until I Win |
| Author: | dakight [ Thu Nov 09, 2006 4:44 pm ] |
Quote: Make sure she doint have a brand new shiny red Super Stock Dodge around if so let me know mate. Thanks Ron Parker
I don't think Pasadena is in Oz.
| Author: | Ron Parker [ Thu Nov 09, 2006 6:17 pm ] |
She could have moved... ya doint ever know unless u ask. Thanks Ron Parker It Aint Over Until I Win |
| Author: | dakight [ Fri Nov 10, 2006 4:01 am ] |
Well, if that A904 came out of the Super Stock Dodge you might just be buying a whole passle of problems, that way that woman drives! |
| Author: | VE Safari [ Fri Nov 10, 2006 3:51 pm ] |
Quote: Well, if that A904 came out of the Super Stock Dodge you might just be buying a whole passle of problems, that way that woman drives!
Maybe that's why the 'box only cost me $36... |
