It is currently Sun Jan 12, 2025 7:27 am
PostPosted: Sat Nov 11, 2006 6:32 pm
Car Model: 1963 Plymouth Valiant
Hello all,
My Swinger's /6 is about ready for a rebuild, but I'd like to keep the car drivable and take my time doing the engine. I've picked up a /6 from an '84 pickup truck that was supposedly running when pulled. Still need to do a compression check, etc, but the plan is to swap it into the Dart to drive while I build the '73 motor.
Any idea of potential problems I'll encounter on the swap? I'm assuming I'll need to re-use my oil pan, and all bracketry. Will the earlier flexplate fit the later model crank?
If this whole operation sounds like too much trouble, I may go back on a hunt for a decent early 70's motor to build/swap and toss the 80's engine.
Max
 Post subject: Easy swap...
PostPosted: Sat Nov 11, 2006 7:35 pm
Just swap your flex plate, oil pan and pickup onto the truck motor and you'll be done...
You only have to worry if the engine was going into a pre-68 vehicle...
On the positive side, you won't have to lash the valves until you swap back to the older slant.
good luck,
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 6 guests
