It is currently Sat Jan 11, 2025 11:46 am
 Post subject: Short pushrods/Lifters
PostPosted: Sat Nov 11, 2006 8:38 pm
Where can I find shorter length pushrods? Custom? Interchange?
Also, can you reuse Solid lifters?
1 More Stupid Question: Could you carefully drill out a lifter to "make" the pushrod shorter? Or would this cause problems?
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Sat Nov 11, 2006 8:45 pm
I don't know where to get shorter pushrods (never needed any), but I do know the answer to the second part of your question.
Old lifters can be reused on the same cam they where used on before. Just make sure to put them back into the exact same holes they came out of.
If you use old lifters on a new cam, you will wipe out a lobe on your camshaft. Lifters are cheap, just by a new set.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sun Nov 12, 2006 12:07 am
www.pushrods.net
I am not sure you could drill a lifter. They are harder than billy hell.
I have reused old lifters on new cams before with no problems. I have seen more people lose cams with new lifters than old ones. :shock:
PostPosted: Sun Nov 12, 2006 5:40 pm
SSRN National Champion
I would not recondmend using old lifters on a new cam . Use the same lifters with the same cam and Match them every galey. Smith Bros can build you any type pushrod you want . From mild to extreme, I have used them in my race engine for three years no problem. You get what you pay for. Thanks Ron Parker :D
It Aint Over Until I Win
Users browsing this forum: Ahrefs [Bot], Bing [Bot], MDchanic and 10 guests
