It is currently Sat Jan 11, 2025 8:51 am
 Post subject: bbd idle speeds
PostPosted: Sun Nov 12, 2006 9:51 am
i did a search but couldn't find anything,
what should the fast and curb idle speeds be on a bbd for a super six setup?
also, from what i read, idle mixture screws should be turned out 2 1/2 turns and then played with from there to get the engine to the point where it just idles smoothly, correct?
should i set the idle speed before i set the idle mixture? thanks
God took you away, then brought you back to me.
PostPosted: Sun Nov 12, 2006 9:58 am
My theory is that you want the curb idle to be as low as you can go and not have it die when you put it in gear; I usually end up at about 500-700 rpm, depending on engine configuration. Not sure what fast idle spec was on that setup w/o checking manual, but I doubt you could go wrong at ~1800.
Setting idle mixture and idle speed by ear is a recursive process; you set the mixture, see what rpm your at, and then drop the idle speed down to where you want it. Then see if you can make it idle better by adjusting the mixture again. If so, you have to drop the speed again. Repeat until you're happy.
It used to take me several cycles of this until I just started tuning mixture w/ a vacuum gauge; now I usually set the mixture once and am close enough at whatever idle speed I want.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Sun Nov 12, 2006 9:56 pm
My D-150 manual says 700 and 1600 I believe. A little higher for auto-trans. Not sure what it would be for other models.
The Old Goat '83 D150 225-2
AKA Ice Titan
Users browsing this forum: Google [Bot] and 9 guests
