It is currently Wed Nov 18, 2026 12:40 am
 Post subject: Tire clearance
PostPosted: Fri Nov 17, 2006 2:07 pm
How much clearance should I maintain arould the rear tire to avoid rubbing the quarter lip. Mearsuring for new wheels. Does the rearend move side to side that much?
PostPosted: Fri Nov 17, 2006 3:36 pm
The rear moves and the tires deform.
This much works for me ('64 Valiant rear):
PostPosted: Fri Nov 17, 2006 3:41 pm
That works for me too. In my case that means 235/60/14.
One finger means 245/60/14 and they rub with a heavy load (5 people and snowboarding gear) and hard cornering.( I live in the Land of Corners and Hills)
But 6.50/13 never rubbed.....~~~~~
PostPosted: Fri Nov 17, 2006 9:36 pm
The pic shows a 205-60R15 on a 15X7 with 13mm offset, stock '64 four-door sedan rear wheelwell.
