It is currently Sun Nov 15, 2026 12:25 pm
PostPosted: Thu Nov 09, 2006 11:17 am
Hi guys,
I found a stash of 10 inch 23 spline A833 10 inch clutch disc, pressure plate and throwout bearings sets for about $60 shipped to you in original packing if anyone is interested in a few. I know this post may be movable to "for sale" but I was thinking to do it like the T5 deal and if 6 or 8 were wanted, get them and move them along to our gang. I am really torn about I oughta get two more for the shelf and probably will since I have been having my wierd clutch chatter from another set. I am putting one of these new ones in my truck this afternoon. Borg Warner 3 finger plates, btw.
rock
'64d100
PostPosted: Thu Nov 09, 2006 12:06 pm
I might be interested, is there a deadline involved?
PostPosted: Thu Nov 09, 2006 12:49 pm
Are these new or remanufactured? The cover is Borg and Beck, how about the plate? What brand is the TO bearing?
Thanks!
PostPosted: Thu Nov 09, 2006 2:20 pm
will fit my car I'd buy it right away. I have a cast iron bellhousing and the flywheel came drilled for a 9.25" borg and beck type PP. If it fits, I'm in.
Juan Ignacio Caino
PostPosted: Thu Nov 09, 2006 9:26 pm
If these are the 10 inch B&B covers for the 122 tooth flywheel (10 5/8 cover mounting bolt circle) then I would be in for one at that price.
PostPosted: Sat Nov 11, 2006 11:27 pm
OK, this is the specs I need too. I'd be in with at least one.
Juan Ignacio Caino
PostPosted: Mon Nov 13, 2006 9:28 am
I would also be interested in a set.
1971 D100 SWB Step side, 225, 3 on the tree, 3.91 gear
PostPosted: Mon Nov 13, 2006 9:52 am
Car Model: 1967 Dodge Dart 270
I'll take 2. Never know when your gonna need them. Let us know.
PostPosted: Mon Nov 13, 2006 1:12 pm
I'm in for 2.
Slant Cecil
PostPosted: Mon Nov 13, 2006 6:20 pm
i'm in for one. let us know on specs.
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Mon Nov 13, 2006 6:39 pm
Rock seems to have abandoned the thread.
PostPosted: Tue Nov 14, 2006 1:38 am
Car Model: 1962 Lancer 770
rock come back to us mate! I know you enjoyed that long weekend, but now we're all interested =)
PostPosted: Wed Nov 15, 2006 8:07 am
OK,
As to specs on clutch...three finger presssure plate, 23 spline, 10 inch disc. I popped a set into the truck (A833OD with stock OD bell) this weekend with NO trouble at all and took Doctor Dodge's advice to use the allen head bolts for the pressure plate..MUCH easier than saying nasty things over hex head bolts close to the pressure plate. (In fact with this disc the tranny slid in easier than I am used to , and I like eashy since I have no tranny jack except my forearms!
The sets were/are sold by Sachs and come with new throwout bearing, pressure plate and clutch disc. I don't have the Sachs number right at hand but you can see the set on their web page. I called Sachs and asked before I bit on buying at such a steep discount (NOT from Sachs) They come in the factory shrink wrapped package that has the cardboard backing you see on the Sachs page but the backing is torn off for mailing in smaller package. Disc is still wrapped in the protective stuff.
I see they have a marking they are rebuilt in Mexico and are not stamped Borg and Beck or B&B, but sure look like Borg and Beck. They have the orange weight springs in the pressure plate. In that nearly $60 delivered to you price I was estimating in $30 for postage, and I sure don't think it would be that much. As much stuff as is made in Mexico now for car manufacturers trying a set at $60 didn't scare me, and as over stocks instead of $200 new, I bit. I think my source still has 6, so if the same folks are still interested, lemme know again and I will get em in the order y'all spoke up before. I am gonna get me two more for the shelf cause the proof was in the driving for me and I am a spare parts junkie!
Now to see if the clutch chatter that started it all is gone after I drive a while. I found the yoke angles at tranny and pinion were different from each other by a few degrees since I had to fabricate a cross member and put in a complete 489 case 3.91 positraction rear end including axle housings and springs. Also, my bearing in the crankshaft was not perfectly vertical in the crank. Hope fixing these did the deal!
rock
'64d100
 Post subject: A couple more specs
PostPosted: Wed Nov 15, 2006 8:19 am
Forgort to say, yep, I use a 122 tooth flywheel with the 10 5/8 bolt circle. I pulled my B+B pressure plate off to put this one on. Argentina, Last year a forum member told me the 10 inch disc fit the 9 1/4 PP so I bought a set from another forum member. He told me the 10 inch nearly touched the PP and it he was right and "nearly" proved to be not touching and it never did touch. Still, we are talking 1/16 to 1/8 inch clearance..close but fine for me. If that close worries you, be warned.. I used brakeclean to remove the new protective stuff from both the TOB and PP for good luck, and the TOB came lightly greased on its interior. Mailing package is a USPS size parcel box.
rock
'64d100.
PostPosted: Wed Nov 15, 2006 9:28 am
OK, if it fits the bolt circle on a 122 tooth flywheel I'll take 2 if there's enough for anyone wich had claimed to be interested. If stock ain't that much I'll take one and let the folks have each their own. Nothing more annoying than having the car sitting over other person's greed for stocking new parts. :wink: . Let me know. I can send you the money via paypal or western pain-in-the-ass union. Tight clearances doesn't worry me at all, using a B&B 9.25" behind a 200 hp ballpark slant six does, I'm affraid it will A)slip B)wear out in no time C) both.
Juan Ignacio Caino
