It is currently Wed Apr 29, 2026 7:09 am
 Post subject: ? about Turbo Cam
PostPosted: Mon Nov 27, 2006 8:25 pm
Hello everyone, This is a first for me on this forum. I have checked (enjoyed) it many times but never joined. I have a question about turbo cams. I'm building a single turbo 225ci and I'm in need of a cam. The people at Clifford claim I need a 106 - 108 lobe center with a "flip flop design" aggressive duration at .050 and lift. The people at Lunati say go with a 114 lobe center and a mild duration and lift. I've always heard that a 114 lobe center is the best for a turbo or blower for many reasons but Clifford says the 6 cyliders need the 106-108 lobe centers to create heat, exhaust force, to spin the turbo. Desired rpm is 6000 - 6500. 15psi boost to start with and work myself up to 25 psi or so. Any suggestions on what cam I should use? Head is ported w/ custom header, hyperpack intake, 4500 stall convertor, 727 trans, 4.30 rear, 650 mighty demon, T70 turbo, greddy waste gate and BOV. Thanks and Later.
Ryan
hrspower@venturewb.net
Ryan Peterson
'66 Plymouth Valiant Signet Slant 6 'Turbo'
www.syntheticsbestoil.com
PostPosted: Mon Nov 27, 2006 10:53 pm
The wide lobe center combined with a mild duration and lift is the way to go when using a turbo.
Stay away from Clifford, they do not design or grind cams.
Make a few more calls to cam grinders and "take notes", you will find that 'in the know" cam grinders will keep a turbo cam pretty mild.
A short overlap event (wide lobe centers) is needed to keep the boosted A/F mixture from from blowing thru during TDCE.
PostPosted: Tue Nov 28, 2006 10:32 am
do they just farm them out then?
PostPosted: Tue Nov 28, 2006 10:41 am
All Clifford does is take orders until they get enough for a run. Nothing is designed or built in house. Used to go through the same crap with Kenne-Bell when I raced a Buick. :shock:
PostPosted: Tue Nov 28, 2006 10:56 am
I used to race Buicks, too, but they usually won... :lol:
vm
PostPosted: Tue Nov 28, 2006 7:15 pm
They insisted they were right even when I suggested the 114 lobe centers. They were also more expensive and needed a core.
Say, what is the quickest ET for a full bodied A-body slant 6? And who is it? Just curious.
Ryan
Ryan Peterson
PostPosted: Tue Nov 28, 2006 9:08 pm
...Say, what is the quickest ET for a full bodied A-body slant 6? And who is it? Just curious.
Ryan
If I remember... it kinda started with this car, running in the 10's :shock:
Then there was this car, that crashed getting into the 9's
And this car, that has made many fast passes and is still going strong!
PostPosted: Wed Nov 29, 2006 1:41 am
This one ran 10.63/124. Is´t crashed after that :(
PostPosted: Wed Nov 29, 2006 12:45 pm
Online
Would the Stock Super Six Cam - 76-80 Be any good for turbo Use?
I dont know much in the way of cam design other than Just Lift and duration.
I understand all the other stuff like lobe seperation, but not as well.
Thanks, Greg
PostPosted: Wed Nov 29, 2006 2:18 pm
Car Model: 1964 Dart GT
Check out Elgin Cams in Redwood City Ca. He custom grinds to spec.
PostPosted: Wed Nov 29, 2006 7:59 pm
I will check with Elgin Cams tomorrow,thanks. Did you guys see the aluminum head on e-bay?
Ryan Peterson
PostPosted: Wed Nov 29, 2006 8:27 pm
Yep we saw it. Their is a thread about it over in the engine section of the forum.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Wed Dec 20, 2006 12:12 pm
I purchased a turbo cam from Engle. TCS-5 114 Lobe centers, intake 227, exhaust 222. I still havent installed the cam yet, but I've running the turbo for about 3 months.
1966 Signet
Turbo Slant Six
PostPosted: Thu Dec 21, 2006 4:29 pm
...but I've running the turbo for about 3 months.
Any more pictures or details? :?:
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
PostPosted: Thu Dec 21, 2006 8:53 pm
I talked to a guy at Elgin cams and filled out a form with my combo but they haven't returned my call. That was about three weeks ago. I'll have to call again. What lift does that cam have from Engle and about what did it cost? Later.
Ryan
Ryan Peterson
