Ready to do ELB removal
https://slantsix.org/forum/viewtopic.php?t=21175
Author:  83miser [ Thu Dec 21, 2006 12:06 pm ]
Post subject:  Ready to do ELB removal
I have New/Rebuilt Distributor and 4 pin module along with single ballast resistor. I intend to make the harness, As it appears very simple with a correct schematic. Once satisfied with results I want to remove anything unnecessary. I also will post a pic of Carter 2bbl in another topic for advice on it. Where should the Dist Vac connect? Any comments or advice is appreciated.
Author:  CStryker [ Thu Dec 21, 2006 1:44 pm ]
Iirc, it's the same port that the vacuum pod on the ELB connected to.
Author:  SlantSixDan [ Thu Dec 21, 2006 5:46 pm ]
I'm not sure that's so...my recollection is that the ELB sees manifold vacuum, while the distributor vacuum advance wants to ssee ported vacuum. I don't think carbs originally used with ELB have ported vacuum available. :-(
